Using Nmap
EtnaBox1
Community Member
I finally got Nmap on my laptop and trying to get familiar with it. I scanned my my own IP address just to see what's going on. I had the following TCP ports opened:135, 139, 445, 2179, 3389. Is it normal to have these ports opened?
M02@rt37
Hello @EtnaBox1
Is it normal ? Yes, but...
it can be risky if these ports exposed to the internet ;  typicaly they are only reachable on your local network behind a home router or firewall. So, to stay safe, keep internal PC Firewal on, disable services you don’t use like RDP or file/printer sharing...
Best regards
Thanks, That was helpful.
