Using output from pwd in current directory
Erik Nihlen
I'm new to EEM in IOS-XR or EEM in general.
I'm looking to use the output from the CLI in the current vty session and use it as a argument to a TCL-script.
Example:
RP/0/RSP0/CPU0:Router(config)#router isis  1
RP/0/RSP0/CPU0:Router(config-isis)#pwd
Mon Mar 17 10:38:01.827 CET
router isis 1
I was thinking a alias that triggers a tcl-script and then executes a command in the same working directory as the user who executed the alias is in or some other way and can save the information from the current session.
Is this is possible?
Joe Clarke
Unfortunately, this is not possible.  The config submode is not passed as a variable to the CLI event detector.
