Using prime to upgrade 3850 stack
LarryBrown4422
I will be upgrading the IOS for a stack of 3850 using Prime. My question is, will Prime upgrade all of the switches in the stack, as this is a remotes site with no local support?
Larry Brown
Seb Rupik
Hi there,
As it is a stack Prime does not support the upgrade process as it requires a .tar file.
Personally I would tread carefully with letting Prime do switch upgrades at remote sites and always do them manually.
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-6/user/guide/bk_CiscoPrimeInfrastructure_3_6_0_UserGuide/bk_CiscoPrimeInfrastructure_3_6_0_UserGuide_chapter_0110.html#con_1076966
cheers,
Seb.
Leo Laohoo
I would not recommend using PI to do any upgrade.
