Using "IF" staement in TCL script to modify a switchport config
Network @RKI
Hi all,
this ist a part of our switch port config on a C9300 with an IOSXE 17.9.X:
interface GigabitEthernet1/0/7
description RADIUS Port
switchport access vlan XY
switchport mode access
authentication priority dot1x mab
now due to some internal issues we have to modify all of the switchports and turn the authentication priority to "mab dot1x".
It's not possible to use the interface-range command because of some ports in between that do not use RADIUS.
So i'm thinking about a TCL script with an IF statement, maybe something like:
if {description equals RADIUS Port or authenticatio priority equals dot1x mab}
set authentication priority mab dot1x
can anyone help with the hole syntax please.
Thanks in advance
Saif
Dan Frey
Give this a try in tclsh mode.
set lines [exec show ip int brief]
set intflist ""
foreach line [split $lines "\n"] {
    if [regexp {^(GigabitEthernet[0-9\/]+)\s+} $line match intf] {
        lappend intflist $intf
set command "set authentication priority mab dot1x"
foreach intf $intflist {
    set desc [exec show interface $intf | inc Description]
    if [regexp {(Description: Radius Port|Description: authentication priority equals dot1x mab)} $desc match description] {
       puts "executing $intf $command"
       ios_config "interface $intf" "$command"
Dan Frey
set intflist ""
Hi Dan,
thanks a lot for the script. It worked
Just one note: the second "set" in the line:
is unnecessary. So it has to be:
 set command "authentication priority mab dot1x"
Best regards
Saif
