DNA Devices backup
How can I obtain and download configuration backups of the C9200, C9300, C9500, ISR, and other network components through DNA, and download them automatically?
Torbjørn
If you have added them to your inventory with valid credentials your DNAC/CC should fetch this automatically. You can read more about this at the below links:
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
DanielP211
DNAC does configuration backuping automatically, to download it use a API. I would recommend the network device archive/clear-text api. You can also setup an external server for device configuration saving under DNA Center -> Settings -> Configuration archive.
BR
****Kindly rate all useful posts*****
