using router as access point
DonTrudeau74599
Trying to configure e2500 as access point but can't enter the default gateway to change settings. Any help out there?
pieterh
1) depends on what you do and how you try to accomplish this.
why would you change the default gateway? this probably still needs to refer to the uplink provider no matter if the the 2550 functions as access point or as router.
I guess you did not enable bridging mode first?
2) you may run the Linksys Connect Setup Software for easy setup?
