Using SNMP to Monitor Nexus for CRC
scubaguy3
I would like to know what OID to use to monitor CRC and input errors on Nexus 5672 and nexus 3148.
AFROJ AHMAD
The OID commonly used for this purpose is
locIfInCRC 1.3.6.1.4.1.9.2.2.1.1.12
part of the OLD-CISCO-INTERFACES-MIB
 http://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.4.1.9.2.2.1.1.12&translate=Translate&submitValue=SUBMIT
Unfortunately I do not see this MIB listed as a supported MIB for the Nexus
You may try polling the above MIB, but may not respond.
The next best options
ifInErrors 1.3.6.1.2.1.2.2.1.14
 http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.2.1.2.2.1.14&translate=Translate&submitValue=SUBMIT&submitClicked=true
and
ifOutErrors 1.3.6.1.2.1.2.2.1.20
 http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=ifOutErrors#oidContent
Please refer the following SNMP Mib objects (ifTable) mapping with router
CLI for these interface counters.
ifInOctets = rx input bytes
ifInUcastPkts = rx unicast packets
ifInNUcastPkts = rx broadcast and multicast packets
ifInDiscards = Not supported
ifInErrors = input errors + runt err + crc err + ecc err + overflow err +
underflow err + sync loss err
ifInUnknownProtos = Not applicable
ifOutOctets = tx output bytes
ifOutUcastPkts = tx unicast packets
ifOutNUcastPkts = tx broadcast and multicast packets
ifOutDiscards =
Bad_etype_drop+if_down_drop+tx_dropped+bad_proto_drop+storm_suppression
ifOutErrors = tx crc errors
ifOutQLen = Not applicable
Hope this will help
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
and
ifOutDiscards =
Hope this will help
Thanks-
Afroz
