USXGMII specification EDCS-1467841 revision 1.4
youcisco
Is it possible to have the USXGMII specification, and any technical description.
5 Replies 5
not sure if this helps:
https://developer.cisco.com/site/usgmii-usxgmii/
Thanks Georg for the answer but in this page we only have the USGMII spec and not the USXGMII
I was afraid that would not be of much use. I basically did a blind Google search...
It seems there is little to none information available, all I get is very short specs like the one linked below:
https://www.intel.com/content/www/us/en/docs/programmable/720989/22-2-20-1-0/usxgmii.html
EDIT: I might as well post the PDF files I found...
Hi Georg,
That's all about I found too, thanks anyways for your help.
David Peng 2024
Is there any way to get the old EDCS-1467841 revision 1.4? Current link at https://developer.cisco.com/site/usgmii-usxgmii/ points to  EDCS-1150953 starting from rev2.0.
