05-08-2006 11:31 AM
Running Campus Manager 4.0.4, we are getting incomplete information on ip phones connected to 3560G-48PS switches, running the latest Lan Base Image. The end-hosts users (PC) are discovered properly on the switch, but in the IP phone table, it does not show the switch and port info for the phones connected to that same switch. (Phone info gathered properly from CCM)
In the IP phone table, we see complete information for other phones connected to 4506 switches.
Any idea?
05-08-2006 02:02 PM
Are the phones all Cisco IP phones? Are they connected via trunk? Also, are the phones actually appearing as end hosts instead of phones?
05-09-2006 03:50 AM
The phones are all Cisco IP Phones model 7940. They are not connected via trunk but using the following commands:
interface GigabitEthernet0/25
description PO A-429.22 # 288
switchport access vlan 111
switchport mode access
switchport voice vlan 778
switchport port-security maximum 3
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
service-policy input IPPHONE+PC-BASIC
spanning-tree portfast
spanning-tree bpduguard enable
On the switch, the phones are discovered and cdp is enabled.
In UT, these phones do not appear as end hosts (other Cisco Phones on 4506 switches are discovered as end hosts).
IOS version on the switch:
c3560-ipbasek9-mz.122-25.SED1.bin
Also, I am unable to use the UT debugger utility for that switch. It does not take the -port gi0/25, even for a port on which the end user has been discovered and added to UT.
