virtual gateway
TECH-JEFF
Level 4
Level 4
Hi, I'd like to know how to create a virtual gateway? is there a command for this?
Jeff
Jefferson Co
Philip D'Ath
Meraki Community All-Star
You can use HSRP.
http://www.cisco.com/c/en/us/support/docs/ip/hot-standby-router-protocol-hsrp/9234-hsrpguidetoc.html
Example:
interface ethernet0
     ip address 10.1.1.1 255.255.255.0
     standby ip  10.1.1.3
Philip D'Ath
You can use HSRP.
Example:
interface ethernet0
     standby ip  10.1.1.3
Thanks Pihilip for the input, will try it in Packet Tracer.
Jeff
Jefferson Co
