Virtualization PI and APIC-EM ?
martinboitz
my question is, it is true that you should not perform VMotion on the tool APIC-EM after virtualization with VMWare?
And when.....why not?
Best regards
Martin
marce1000
 - Not true
>Why not ?
  It would also , then help, if you provide the argumenting-source (info) and it's motivations.
M.
Hallo marce1000,
thank you for your mail.
My consideration is to buy the APIC-EM. Now the only question is whether it should be bought as a hardware appliance or as an OVA. My PI3.x.x runs as a hardware appliance and I am very happy with it.
Now I heard from my CONSULTING SYSTEMS ENGINEER (SALES) that this problem exists in VMWare.
...But maybe I can ask you...
you tested vMotion on your own APIC-EM-ESXi successfully?
And after the vMotion APIC-EM runs?
Which ESXi version did you use?
Which APIC-EM version did you use?
Best Regards
Martin
 From the link below I get :
In addition to acquiring a dedicated Cisco APIC-EM physical appliance with the ISO image preinstalled and tested, you can also install the Cisco APIC-EM ISO image in a supported virtual environment. You may want to do this for testing the controller within your network, prior to setting up the appliance.
 - This  seems to indicate that VM based solutions for APIC-EM are only intended for testing purposes and that you should go for an appliance in the end.
  https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/application-policy-infrastructure-controller-enterprise-module/1-1-x/hardware-guide/b_apic-em_hardware_install/b_apic-em_hrd_install_chapter_0100.html
M.
Hallo marce1000,
thank you for the answer.
But you have not answered my questions. But thanks for your guess ... it's a good Note.
Is there anyone in this forum who has ever done such a test?...In this constellation?
Best Regards
Martin
