VLAN, BRIDGE-MIB and SNMPv3 contexts
ww9rivers
I found some commands in this Cisco document (ID 44800) for reading BRIDGE-MIB objects on a per-VLAN basis. I have also found information in the furoms and elsewhere about SNMPv3 access to such information.
My understanding is that, one must configure each and every VLAN in a context to allow an SNMPv3 user access to them.
Is that a correct and current understanding?
If so, it seems to be difficult to scale accross a few hundreds of devices. What is the best practice for allowing an SNMPv3 user access to all things on all devices?
Joe Clarke
In the past it was required to configure access to each "vlan-*" context.  Newer versions of switch code support a "match prefix" syntax that makes scalability easier.  To allow all VLANs configure something like the following:
snmp-server group v3group v3 auth context vlan- match prefix
