VLAN Port Assignment is disabled
mnewnam01
On the VLAN Port Assignment screen I can find and select ports that I want to change the VLAN and I can select the VLAN to change to from the drop-down menu ("Move selected ports to"), but the Move button is grayed out. I have restarted Campus Manager and the ANIServer, but the Move button is still disabled. Anyone experienced this before? Thanks
pradeepde
Level 5
Level 5
You can use VLAN Port Assignment to:
 View and find port information in a VTP domain
 View port, device, and trunk attributes
 Show and highlight a selected device or VLAN in the VTP domain view
 Configure VLANs on a trunk
check out the following link for more information on VLAN Port Assignment :
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_user_guide_chapter09186a00803f3709.html#wp1046900
b.smeets
You may have not enough privilege (your 'role' in Server Settings > Security) to do this.
