VoIP VLAN on Packet Tracer: phones don't recieve IPs
Nestor_Te
Hi all!
I'm not an IT guy, I'm taking the first steps, learning the Cisco system for myself, and from time to time I have questions that are probably a little stupid, but I can't find answers in the documentation or Internet.
I compose a network in Packet Tracer of 2811 router, 2960 switch and three 7960 phones. When I start telephony service, the phones are assigned numbers and everything works. But if I make the same settings not on VLAN 1, but make a separate VLAN and do same configuration there, phones cannot receive an IP addresses, although the configs differ only in the VLAN number. What did I forget to do? What else needs to be configured to move the phones to a separate VLAN?
2 Accepted Solutions
yes, i see issue; maybe PT does not support other configs
see https://learningnetwork.cisco.com/s/question/0D53i00000KsnLrCAJ/vlan-question-how-do-nodes-automatically-find-a-vlan-on-a-cisco-switch
no need for ip helper-address 172.16.0.1 anywhere in your lab.
Regards, ML
**Please Rate All Helpful Responses **
8 Replies 8
balaji.bandi
when you change the VLAN the Interface VLAN need to mention where the DHCP Server
interface vlan X
ip helper-address x.x.x.x  (dhcp Server to get DHCP IP)
BB
Thank you for answer! I did that but my phones still indicates "Configuring IP" messages.
For a better understanding of problem I'll show my configs, maybe I miss something
Spoiler
Router#sh run
Building configuration...
Current configuration : 1004 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip dhcp excluded-address 172.16.0.1
ip dhcp pool Phones
network 172.16.0.0 255.255.255.0
default-router 172.16.0.1
option 150 ip 172.16.0.1
ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn FTX1017946S-
spanning-tree mode pvst
interface FastEthernet0/0
ip address 172.16.0.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0060.70c7.a901
no ip address
ip classless
ip flow-export version 9
telephony-service
max-ephones 4
max-dn 4
ip source-address 172.16.0.1 port 2000
auto assign 1 to 4
ephone-dn 1
number 11
ephone-dn 2
number 12
line con 0
line aux 0
line vty 0 4
login
end
Spoiler
Switch#sh run
Current configuration : 1222 bytes
version 15.0
hostname Switch
switchport voice vlan 10
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
no ip address
line con 0
line vty 0 4
login
line vty 5 15
login
end
Martin L
you attach your PT file here in a zip format so that we can check it out;
Regards, ML
Nestor_Te
Of course, that is my file. Thank you!
Regards, ML
Thank you very much for the answer!
So, if I understood correctly, on real switches and routers it is possible to set up a separate voice VLAN, but in PT the functionality is limited, so it is impossible to do this?
Upd. I changed VLAN 10 to 1 and everything worked. It's probably really a limitation of the program.
yes, real switch has 4 ways to configure that special voice " mini-trunk " port as u see in CLN post, (note: attached picture shows only 2 connections).  I guess PT developers have not worked out such options.  What works or not in PT should be displayed under PT Help menu,
Real switch voice port options should be
switchport voice vlan {vlan-id | dot1p | untagged | none}
Regards, ML
