WAN Layout With LMS 3.2
nizar.houichi
Dear all,
I have installed Cisco Works LMS 3.2 to adminsitrate and monitor 100 routers connected via Frame Relay Link and IP MPLS connection. I have added all the routers and associate them to the campus manager module. On the toplology services, I have all routers as not connected and reacheble devices. I would like to show the WAN links on the topology, how can I do for that?
Thanks In advance
Houichi Nizar
Marvin Rhoads
Campus Manager will only display WAN links if you have a layer 2 connection between your devices over which CDP broadcasts will work. This can be difficult with 3rd party providers in the loop.
One possible work around is to use a GRE tunnel and activate CDP on the Tunnel interfaces. Of course, that's still not a complete picture of your environment.
Hope this helps.
Marvin Rhoads
Hope this helps.
