Web GUI on 93108TC-FX
chrisdale
Hi Community,
A daft question here. Can the 93108TC-FX  support GUI access? I have done some checking into this which the documentation doesn't mention this ability. When checking the features on the switch, I do not see anything for http. As traditionally, you needed to set up some basic http commands for this to work. As this is missing from the platform, does anyone have any links to a definitive answer?
Thank in advance
marce1000
            - These devices (running nx-os) don't support GUI access ,
 M.
marce1000
 M.
Max Jobs
You can use Prime as a management platform. NX-OS does not have any embedded Web service. But you can also use Fabric Dashboard. Take a look at this link:
https://www.cisco.com/c/en/us/products/cloud-systems-management/prime-data-center-network-manager/index.html
chrisdale
@marce1000 Thank you, this is exactly what I thought. Thank you for confirming.
