Web Interface of Cisco Prime 2.1 not working
oneone_26
Excuse me!
I install the trial version cisco prime 2.1 (OVA) on ESXi server
I can ping cisco prime but web interface of cisco prime not worinking
prime/admin# ncs status
Health Monitor Server is running.
Ftp Server is running
Database server is running
Tftp Server is running
Matlab Server is running
NMS Server is running.
Plug and Play Gateway is running.
SAM Daemon is running ...
DA Daemon is running ...
Syslog Daemon is running ...
AFROJ AHMAD
Services running fine..
check it with other Browser , Supported browser are below::
–    Google Chrome 31 or later.
–    Microsoft Internet Explorer 8.0 or 9.0 with Google Chrome Frame plugin (users logging in to the simplified Lobby Ambassador interface do not need the plugin).
–    Mozilla Firefox ESR 24.
–    Mozilla Firefox 24, 25 or 26.
If above does not help , reboot the server once and check the issue again.
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Thanks-
Afroz
I use third browser
- ie 8.0
- chome 36.0.1985
- firefox 31.0
not working
i reboot server and check status But web interface not working
was it working before ?
Is this the first time you are trying to login ?
share the error when you try to login ?
Also check if the below file has the correct IP address ::
/opt/CSCOlumos/conf/messaging.properties
Thanks-
