07-15-2008 11:16 AM
In CiscoView, when a port is green, does that mean that there is a cable connected to the interface AND connected to a device (a PC) on the other end? Would it be green if the other end was not connected to a device, but connected to the port? what if the device (a PC) were shutdown, would it be green?
07-15-2008 11:22 AM
Green typically means the port is connected (meaning its status is up/up). That means a cable is connected to the port, and the other end is connected to a device which is powered on, or otherwise providing a link beat.
Some PCs that are plugged in, but powered off still provide link to support features like WakeOnLAN.
07-16-2008 06:43 AM
Just to clarify, if the interface is red, it is enabled but nothing is connected? and/or it is possible that something is connected it is just shutdown?
We are trying to use CV to determine the number of total ports a site is using, by counting the number of green interfaces....
07-16-2008 08:53 AM
Each device package can use colors for its own purposes, so check the color legend when viewing each device type.
If you want to get a list of total ports in your network, you should consider using the Campus Manager switch port reports instead. These are found under Campus Manager > User Tracking > Reports > Report Generator > Switch Port Report in LMS 3.0 and higher.
