Configuring SNMP RW strings
sirbaughmf
In previous versions of LMS you could update the a anisnmp.conf file with the RW string and it would be used in the application. LMS 2.6 has the discoveysnmp.conf file, but the RW string is not read in the application. Is there a way to manually configure the RW string instead of going through the GUI?
Joe Clarke
Not in LMS 2.6. In LMS 3.0, we introduced a feature called Default Credentials which allows you to specify ALL credentials that a new device can inherit when it is added to DCR.
