What openssl version used by cisco prime LAN management solution 4.2.5?
samhoface1
Hi All,
I have search the cisco website for this question but still cannot get the result. I only find the openssl version of LMS 4.2.2, LMS 4.2, LMS 4.0, which is 0.9.8n.
Are LMS 4.2.5 using openssl 0.9.8n, or above?
Thank you.
2 Accepted Solutions
Vinod Arya
Ideally Components like OpenSSL are not changed frequently. So i expect it to be still the same # 0.9.8n.
I also havent been able to find the document which shows the version of OpenSSL on LMS 4.2.5.
But you can check the version within the server. OpenSSL executable is available under following directory :
     $NMSROOT\CSCOpx\setup\support
You can CD to this directory and run command openSSL version to see the version.
Please check output from my LMS 4.2.4 (on windows):
C:\Program Files (x86)\CSCOpx\setup\support>openssl.exe version
OpenSSL 0.9.8n 24 Mar 2010
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Sam,
Glad to know it was helpful.
Please mark this thread closed/Answered if it is resolved.
-Thanks
Vinod
Vinod Arya
-Thanks
Vinod
Thank you Vinod for replying.
It is a great help with the openssl version of LMS 4.2.5.
Best Wishes,
Sam
Sam,
-Thanks
Vinod
