when ASA configuration is backed up, we see configuration is modified by user on ASA
umakanthreddy
Please let me know why this happens.
Joe Clarke
If you mean when the config is backed up by LMS, yes, this can happen depending on the version of LMS and the version of code running on the ASA.  RME needs to enter config mode to disable the output pager on certain versions of ASA OS (i.e. to enter the "no pager" command).  Newer versions of LMS and ASA code should not be affected.
