when not to use loopback?
Mohit Chauhan
Level 5
Level 5
Hi guys,
It seems very simple question, but it made me go thinking and thinking and decided it would be worthwhile to share it here with you.
I am building a small network with one core switch doing all inter vlan routing and connecting to two edge routers (these routers are used for different purpose).
I am planning to use a management vlan having all the switches as part of it. And I was thinking of using loopback interfaces on the routers and use static routing so the core knows where they are located.
My question (which may seem stupid here ) was to ask whether having loopback here would be really worthwhile? or if there is a better way in regards to management of the network devices?
Mo
John Blakley
having a loop back really only makes sense if you have more than 1 path into the router. If you have a single network connection into the switch and that connection goes down, having a loop back wouldn't help much.
Hth,
John
HTH, John *** Please rate all useful posts ***
