which programming language has the best library for ssh into Cisco Router/Switch
homephoneone
I need to create a web app to load config for routers and switches
interace with TCL.
which programming language has the best library ssh into Cisco Router/Switch.
Run commands to loading config files and etc...
5 Replies 5
Joe Clarke
Just about any language can be made to work.  Perl, for example, has a number of modules that make SSH and telnet access to Cisco devices easy.  However, I find the Expect language easiest to just do simple automations with devices since you don't need any additional libraries.  All you need is a command line ssh client.
isn't Expect limited compare to like PHP or Perl?
I guess that depends on what you mean by "limited."  I find it very functional for being able to grab data off of Cisco devices as well as make configuration changes.
hugozaggo
I've had great success with Python+Paramiko (http://www.lag.net/paramiko/).
Python is a programmer-friendly language, and Paramiko is very easy to use.
I found it much easier to work with than Expect, and you can use the whole Python language + extensive standard and non-standard libraries to solve your problems.
Give it a try.
I will try Paramiko
