will a WIC-1DSU-T1 V2 work on a 2900 routers or 1921 ?
dolanduck.
marce1000
- If you have on 'in place' issue show diag which will give info as to being supported or not , otherwise check the info's below :
 https://www.cisco.com/c/en/us/products/routers/2900-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
 https://www.cisco.com/c/en/us/products/routers/1900-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
 M.
