wired clients not shown in PI 2.2
I have a problem concerning Prime Infrastructure 2.2:
After upgrading from version 2.1, the wired clients in the "client count"-dashlet are only shown if you log in as root.
Other users can's see them since the upgrade.
Thanks in advance.
Toivo Voll
Do you mean that you can add the dashlet to non-root users, but it won't show up for them? Or is it possible that the dashboard config / layout is different for the two different users, so you just need to add the missing dashlets for non-root users?
