Wireless Controller WLAN GUEST web authentification
Nadia Bbz
Level 4
Level 4
Dear Team ,
I created wlan  wireless_guest  web authentication using local authentication , everything works well
i have only one problem ,after web authentication ( username and password) click to submit user get access to entire corporate network , how to just allow access to the internet
thanks for help
Mark Elsen
 - You don't describe your wireless setup , but you will have to become more familiar  with basic WLAN/SSID's setup. In a controller based environment you can for instance assign  a 'guest-vlan' to the guest network which can be separated from the standard Intranet and have Internet access.
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
hey @Mark Elsen ;
Thanks for reply ;
that's what i want to do
in My controller , i created a vlan Guest , i assigned it to wlan\ SSID Guest using local authentication (web policy)
My issue it's how to assign ACL ( permit just access to internet ) to this vlan after successful authentication
Thanks again
 - Better is have a separate vlan for guest users ; you will however find numerous example resources about this when using Google with your related keywords. Here are a few examples from Youtube (too) :
  https://www.youtube.com/watch?v=7ni9gj_W6sM
  https://www.youtube.com/watch?v=5IW_PsrvjKA&t=1135s
 M.
