Wireless Lan Controller PSK reset after manual fail-over
mattblue84
Hi All,
We have two Wireless Lan Controllers running in HA (5508 - 7.6.130.33).
We had an infrastructure is which caused a fail-over from the primary to the secondary controller.
We manually failed back over from the secondary to the primary controller and we beleive this cased an issues with a PSK we have configured for an SSID, we had to reset the PSK after the manual fail-over.
Been looking through doco but unable to find anything relevent
Can anybody confirm if this behavior is normal?
Thanks in advance
Matt
Leo Laohoo
Post the complete output to the command "sh coredump summary".
Hi Leo,
Unfortunately coredump is not enabled - the last dump was in 2014
Thanks for replying
Matt
