privilege command use.
Chris McCann
Level 4
Level 4
Hi Folks,
I am trying to use the privilege command to restrict access on a switch. Basically I wish to have users the abiltity to reset an interface using shut/no shut.
I have set the username up with privilege 7. Also setup an enable password with level 7.
privilege interface level 7 shut.
However when I log in with my new user and enable 7 I can get into conf t no problem but cannt access the interfaces, any advice please.
Chris.
Milos Megis
Level 8
Level 8
Try these commands:
privilege interface level 7 shutdown
privilege configure level 7 interface
privilege exec level 7 configure terminal
Milos Megis
Level 8
Level 8
Try these commands:
Hi Milos,
Yes I ended up finding out and have done the below. many thanks for your reply.
privilege interface level 7 no shutdown
enable secret level 7 *****
