10-12-2020 02:45 AM
Hi,I need an explanation of connection between Switch and WLC.My questions are:
1.why cant ping from switch to wlc
2.why AP cant establish CAPWAP tunnel with wlc
switch conf:
ip routing
vlan 10 *create vlans
vlan 20
inter vlan 10
ip add 10.10.10.1
ip helper-add 10.10.10.5
ip forward-protocol udp 5246
inter vlan 20
ip add 10.10.20.1
inter fa 0/1
sw trunk encapsul dot1q
sw mod trunk
inter fa 0/2
sw mod acc
sw acc vlan 10
ip dhcp pool ap
net 10.10.10.0
def g. 10.10.10.1
ip dhcp pool guest
net 10.10.20.0
def g. 10.10.20.1
ip dhcp excluded-add 10.10.10.1
10.10.10.5
10.10.20.1
10-12-2020 06:01 AM
we must check the WLC and AP config
10-12-2020 08:29 AM
my knowledge is that AP doesn't require conf. They pick up ip from DHCP server(switch in my case) and automatically create CAPWAP tunnel with Switch.
About WLC conf it comes after. My problem is Switch conf. If I said something wrong correct me.
