WLC GUI
AndreasGrossen
Hi all
I try to connect to the GUI of the WLC 5520 over the management interface.
The management interface has following ip: 10.123.6.181
Ping is working.
But i cant access GUI over this IP address.
Following network Configuration:
(wczhlab01) >show network summary
RF-Network Name............................. SIXMobGrp
DNS Server IP............................... 10.123.19.11
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Enable
Secure Web Mode Cipher-Option SSLv2......... Disable
Secure Web Mode RC4 Cipher Preference....... Disable
Secure Web Mode SSL Protocol................ Disable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Secure Shell (ssh) Cipher-Option High....... Disable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
IPv4 AP Multicast/Broadcast Mode............ Unicast
IPv6 AP Multicast/Broadcast Mode............ Multicast Address : ::
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
MLD snooping................................ Disabled
--More-- or (q)uit
MLD timeout................................. 60 seconds
MLD query interval.......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Enabled
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Enable
Mgmt Via Dynamic Interface.................. Enable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
Mesh Backhaul RRM........................... Disable
AP Fallback ................................ Enable
Web Auth CMCC Support ...................... Disabled
Web Auth Redirect Ports .................... 80
Web Auth Proxy Redirect ................... Disable
Web Auth Captive-Bypass .................. Disable
Web Auth Secure Web ....................... Enable
Web Auth Secure Redirection ............... Disable
Fast SSID Change ........................... Disabled
AP Discovery - NAT IP Only ................. Enabled
IP/MAC Addr Binding Check .................. Enabled
Link Local Bridging Status ................. Disabled
--More-- or (q)uit
CCX-lite status ............................ Disable
oeap-600 dual-rlan-ports ................... Disable
oeap-600 local-network ..................... Enable
oeap-600 Split Tunneling (Printers)......... Disable
WebPortal Online Client .................... 0
WebPortal NTF_LOGOUT Client ................ 0
mDNS snooping............................... Disabled
mDNS Query Interval......................... 15 minutes
Web Color Theme............................. Default
Capwap Prefer Mode.......................... IPv4
Network Profile............................. Disabled
Client ip conflict detection (DHCP) ........ Disabled
Mesh BH RRM ................................ Disable
Mesh Aggressive DCA......................... Disable
Mesh Auto RF................................ Disable
HTTP Profiling Port......................... 80
Does somebody can help me?
Cheers
Andi
11 Replies 11
Leo Laohoo
HTTP is disabled.
Have you tried HTTPS?
Yes HTTPs also doesn't works.
Cheers
What error message are you getting when trying to access the WLC via HTTPS?
HI
I get following error message. Look attachment
You say "Ping is working". How did you access the WLC, via SSH/Telnet or console?
Im connecting over console.
How can i add a SSH User? the local user i set didnt works for SSH.
Wait ... So you can only ping?
Ping what address?
What happens if you disconnect the ports to the WLC? Can you still ping the address?
ping the IP of the Management Interface.
When the interface is down i cant ping.
Use a different browser.
I have two other WLC and this are working with the same browser.
Wait a second ... I think I know what this is!
This is a 5520 isn't it? What SFP module is used on the WLC? Is this an SFP or SFP+?
