WLC-PI-MSE is connected, but Active clients are not included in MSE.
CCC3
Although WLC-PI-MSE was linked,
Active Clients are not counted in MSE.
And the client is displayed in PI, but is not visible on the map.
WLC-8.3.143.0
PI - 3.4
MSE-8.0.140.0
Thank you.
pieterh
PI  and MSE , long time since i've used it
but I recall you need to assign the map to the MSE , has this been done ?
Configuration and Deployment Guide for MSE Software Release 8.0 High Availability - Cisco
section : Managing them from Cisco Prime
step 7: It is optional to assign maps and synchronize MSE services.
optional in above text does not mean you can skip this step,
you need to assign a map to  the MSE if you want to process the data for this map,
but you can assign different maps to different MSE's
so every time you create/add a map you need to assign this to an MSE
