WLSE - failed to generate snmp fault
a.gesse
Hi there,
if somebody uses WLSE for snmp fault generation ?
I can not force Dot11.b produce fault alert for Adminstatus -
this is for case when interface is shutted down administratively.
Other types of snmp alert I can trigger successfully - like snmp
reachability, WDS authentication and some else.
The WLSE version is 2.9.1a.
Any tips would be greatly appresiated.
Alex
rmushtaq
Level 8
Level 8
Are you talking about the SNMP unreachable fault?
Actually not, snmp unreachable fault works fine.
What does not work is Adminstatus fault for Dot.11b.
Alex
