WLSE Module
6tgreene
I have wireless and use the WLSE to manage the AP's. The question I have is when I move an AP will the WLSE update automatically or do I have to make the change manual. If it is manual how do I make the change. Thanks
bstremp
Level 2
Level 2
The method for an upgrade to WLSE 1.3.x:
Downloads the ISO recovery CD images
Reassemble and burn them onto a CD
Uses the recovery CD to upgrade
http://www.cisco.com/en/US/products/sw/cscowork/ps3915/products_tech_note09186a008016970b.shtml#um
jlhainy
Level 2
Level 2
I believe you will have to move them manually, just like you had to place them manually in location manager during the initial setup.
