Wrong SNMP values for ciscoEnvMonSupplyStatus
vesk01
Hello everyone,
we are facing the following issue: the SNMP poll is showing wrong values for ciscoEnvMonSupplyStatus when at the same time the "show env all" shows that there is nothing wrong with the power supplies.
Here is the example:
ciscoEnvMonSupplyStatusDescr.1057   Sw1, PS1 Faulty, RPS NotExist                  OctetString                  192.168.49.28:161
ciscoEnvMonSupplyStatusDescr.1058   Sw1, PS2 Faulty, RPS NotExist                  OctetString                  192.168.49.28:161
ciscoEnvMonSupplyState.1057                                     notFunctioning (6)                        Integer                          192.168.49.28:161
ciscoEnvMonSupplyState.1058                                     notFunctioning (6)                        Integer                          192.168.49.28:161
------------------ show env all ------------------
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 31 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1A  C3KX-PWR-350WAC     AZS161803GQ OK              Good     Good     350/0
1B  C3KX-PWR-350WAC     AZS161803GT OK              Good     Good     350/0
I have seen that this is a more or less a known issue and there are plenty of bugs for it, but exactly for our hardware and IOS (C3560E Software (C3560E-IPBASEK9-M), Version 15.0(2)SE2, RELEASE SOFTWARE (fc1)) I cannot find any exact information.
Please, advice if we are hitting some known bug which I cannot locate.
Vesselin
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
Hi ,
I have issue while generating alerts for the CISO nexus device.
snmp laert tool: Solarwinds error : The OID is not supported,
Can anyone tell me the OID for the CISCO nexus 2k, 5K devices.
I am trying to generate the Temp alert.
THANKS
