ZTP Cat9K - Python Guestshell - Clean Software Packages
mgns
Visitor
I'm trying to clean old software packages on Cat9300 Switch during ZTP.
The command "request platform software package clean switch all" shows following confirmation prompt "Do you want to proceed? [y/n]".
I tried to use an EEM script with Action 3.0 as confirmation:
cli.configurep([
"event manager applet clean" ,
"event none maxrun 300" ,
"action 1.0 cli command \"enable\"" ,
"action 2.0 cli command \"request platform software package clean switch all\",
"action 3.0 cli command \"y\" "
and then cli.execute("event manager run clean")
But it is not working.
An other idea: Can I modify the prompt for which the method cli.execute is waiting?
Thanks and best regards,
Magnus
Hi Seb,
Thanks for your hint. I found the following variable $(SWITCHNAME), so action 2.0 looks like this:
"action 2.0 cli command \"request platform software package clean switch all\" pattern \"proceed|$(SWITCHNAME)#\" "
Finally, it works.
Seb Rupik
HI there,
For interactive CLI prompts use the pattern command. Try replacing action 2.0 with:
"action 2.0 cli command \"request platform software package clean switch all\" pattern \"proceed\",
cheers,
Seb.
Thanks, Sep. It works!
But there is one problem: If there are no old packages, the pattern is never true. (see output below)
host#request platform software package clean switch all
This operation may take several minutes...
Running command on switch 1
Cleaning up unnecessary package files
No path specified, will use booted path flash:packages.conf
Cleaning flash:
Scanning boot directory for packages ... done.
Preparing packages list to delete ...
cat9k-cc_srdriver.16.12.01.SPA.pkg
File is in use, will not delete.
cat9k-espbase.16.12.01.SPA.pkg
cat9k-guestshell.16.12.01.SPA.pkg
cat9k-rpbase.16.12.01.SPA.pkg
cat9k-rpboot.16.12.01.SPA.pkg
cat9k-sipbase.16.12.01.SPA.pkg
cat9k-sipspa.16.12.01.SPA.pkg
cat9k-srdriver.16.12.01.SPA.pkg
cat9k-webui.16.12.01.SPA.pkg
cat9k-wlc.16.12.01.SPA.pkg
packages.conf
done.
SUCCESS: No extra package or provisioning files found on media. Nothing to clean.
host#
Can I run a cli command only for a specified pattern? Like if pattern "proceed" then "y" else if pattern "host#" then "do nothing"?
Magnus
hmmm I suppose it doesn't matter it you type 'y' in EXEC mode, so you could change the pattern to regex logical OR:
"action 2.0 cli command \"request platform software package clean switch all\" pattern \"proceed|<host_name>\",
...I am sure there is a built-in EEM variable representing hostname but I can't recall what it is. In which case you will need to substitute <host_name> on each EEM script instance.
cheers,
Seb.
Hi Seb,
Finally, it works.
