Network Wide Alert Settings API
Hi All,
Is there an API for the networkwide - alerts ?
I want to set alerts for config changes for all networks in an org.
Thank you in advance
JasonMo
8 Replies 8
aleabrahao
Meraki Community All-Star
You can enable It on the dashboard:
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
For one network only, I have like 300 networks between wire, wireless, and MX. I need the API to automate that
aleabrahao
Well, you're going to have to have a script, which is also going to take some work, so I don't know what a certain advantage would be.
https://developer.cisco.com/meraki/api-latest/#!update-organization-alerts-profile
aleabrahao
For that reason I like to use templates. 😅
Philip D'Ath
You might want to first read the current alerts for the network:
https://developer.cisco.com/meraki/api-v1/#!get-network-alerts-settings
and then use this to update the alerts (after adding the one you want):
https://developer.cisco.com/meraki/api-v1/#!update-network-alerts-settings
Ah @Philip D'Ath, I should have refreshed my screen before answering as I think I was 15 minutes behind your answer. Credit to you! 🙂
Thank you ! that's what i was looking for, and it worked
JasonMo
For network-wide alerts you can use the following endpoint.
