Technical Issue Meraki
ffatnass
Can we configure for some portforwards a geo location from where these portforwards are allowed.
With Layer 7 rules you can effectively set restrictions but then this is for both incoming and outgoing traffic and not just for that particular portforward
aleabrahao
Meraki Community All-Star
Hi @ffatnass
It is not possible to apply geolocation to port forwarding.
You can only define specific IPs or the range of IPs that can reach the destination.
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
aleabrahao
Hi @ffatnass
Thank you so much for the quick response Alemabrahao!
