5585-X upgrade problem
ergin.sezgin
In my case, I have Cisco ASA 5585-X software asa825-smp-k8.bin and I want to go to software asa847-smp-k8.bin.
I did like in the link below but I've had many problems.
https://supportforums.cisco.com/docs/DOC-12690
Example;
before upgrade access rule number: 110
after upgrade access rule number: 760 !!!
for a new generation of easier options do you have an update?
Julio Carvajal
Hey just in case you want to check my blog and read about a post where I talk about this:
http://www.laguiadelnetworking.com/asa-8-3-upgrade-new-features-known-issues-best-practicesetc/
Try what I suggest and let me know how it goes!
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
