AAA TACACS help on Nexus9k
RyanPowers9691
On cisco 93180 n9k - How can I configure aaa authentication using ISE TACACS while giving that user access to all exec commands on the device? My current configuration looks to TACACS for authorization of commands but I just want to configure the device to give any TACACS authenticated user full exec privileges.
current configuration:
aaa authentication login default group TACACS_LIST local
aaa authorization commands default group TACACS_LIST local
I tried setting the authorization command to default local but then it just takes away all permissions for anyone authenticated through TACACS.
M02@rt37
Hello @RyanPowers9691,
The "aaa authorization exec" command authorizes users for all EXEC sessions after they have been successfully authenticated through TACACS+. The "if-authenticated" keyword allows any user authenticated by TACACS+ to execute any EXEC command on the device.
Note that this configuration only provides authorization for EXEC sessions. If you also want to provide authorization for configuration changes, you should use the "aaa authorization config-commands" command instead of "aaa authorization exec".
Best regards
none of the following commands are present on the nxos device:
if-authenticated
I think M02@rt37  meaning here
for all exec command
aaa authorization commands  {console | default } {group group-list [ local ] | local}
for config-t command
aaa authorization  config-commands {console | default } {group group-list [ local ] | local}
sorry, there is no if-auth with authz in NX-OS
