Activation Key Problem
talha_490
Level 3
Level 3
The current activation key has the support of DES. we have to upgrade it for 3DES and AES.
Can i get the acivation Key from Cisco for free?
Would that activation Key be a Demo version or not?
Do i need to purchase the Activation Key from Cisco?
2 Accepted Solutions
jmia
Level 11
Level 11
If you go here:
https://tools.cisco.com/SWIFT/Licensing/jsp/formGenerator/Pix3DesMsgDisplay.jsp
And follow the instruction, you should be ok.
Hope this helps and please rate posts!!
scheikhnajib
Level 5
Level 5
Mate,
By default, all PIX units will ship with DES only and in order to get the 3DES/AES you need to use the 3DES/AES activation page on Cisco's website.
This is done by Cisco to make sure that you are not using high end cryptography in a dodgy country 🙂 and it's for free, all you need is the serial number of your PIX.
The activation key is a set of characters that you will enter in your PIX by using the "Activation-key" command and once you reboot your PIX you will have the high end encryption.
Cheers.
S.
jmia
Level 11
Level 11
If you go here:
scheikhnajib
Level 5
Level 5
Mate,
Cheers.
S.
