Active/Standby failover problem. Interface state 'waiting'
Below is the show failove on my secondary firewall. I am using 2 cisco asa 5520 for active standby failover. The cable between the failover interface is a straight cable. Can somebody help me to figure out why the interfaces are in a waiting state? especially outside interface.
Failover On
Failover unit Secondary
Failover LAN Interface: bds-failover GigabitEthernet0/2 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 3 of 250 maximum
Version: Ours 8.2(1), Mate 8.2(1)
Last Failover at: 09:32:25 UTC Oct 20 2011
        This host: Secondary - Standby Ready
                Active time: 140 (sec)
                slot 0: ASA5520 hw/sw rev (2.0/8.2(1)) status (Up Sys)
                  Interface outside (10.10.10.11): Normal (Waiting)
                  Interface management (0.0.0.0): No Link (Waiting)
                  Interface inside (192.168.6.2): No Link (Waiting)
                slot 1: empty
        Other host: Primary - Active
                Active time: 12768 (sec)
                  Interface outside (10.10.10.10): Normal (Waiting)
                  Interface inside (192.168.6.1): No Link (Waiting)
                slot 1: empty
Stateful Failover Logical Update Statistics
        Link : bds-failover GigabitEthernet0/2 (up)
        Stateful Obj    xmit       xerr       rcv        rerr
        General         1675       0          3403       0
        sys cmd         1672       0          1672       0
        up time         0          0          0          0
        RPC services    0          0          0          0
        TCP conn        0          0          0          0
        UDP conn        0          0          0          0
        ARP tbl         3          0          1731       0
        Xlate_Timeout   0          0          0          0
        VPN IKE upd     0          0          0          0
        VPN IPSEC upd   0          0          0          0
        VPN CTCP upd    0          0          0          0
        VPN SDI upd     0          0          0          0
        VPN DHCP upd    0          0          0          0
        SIP Session     0          0          0          0
        Logical Update Queue Information
                        Cur     Max     Total
        Recv Q:         0       17      17077
        Xmit Q:         0       1       1741
Pratik
19 Replies 19
This is interesting :-). Couple of tests....
1. Try with xover cable between ASAs.
2. Make a change on primary and see if that replicates to secondery (with HP switch in place).
If all seems good, then this may be a cosmetic bug with OS. I do not see any bug for 8.2(1) but there is something related
to 8.2(2) if not the same. Check the bug# CSCte79575.
I suggest you contact TAC.
Thx
MS
MS,
I have made changes on primary and it does replicate in secondary. So replication is good.
I think I will contact TAC now. Will keep you posted.
Pratik
Sure. Also if not done yet, you can also try to remove the cable from 3900 where Pri ASA is connected and see if the
secondary take over. That way you can make sure that your failover works with no issues.
Thx
MS
MS,
Failover works perfectly now!!!
I had to use a switch between the 2 Cisco 3900s and 2 Firewalls. All interfaces of switch part of same vlan.
Thanks for all your help!!!
Pratik
Glad to hear that. Thanks for the update.
Thx
MS
