Active/Standby failover problem. Interface state 'waiting'
Below is the show failove on my secondary firewall. I am using 2 cisco asa 5520 for active standby failover. The cable between the failover interface is a straight cable. Can somebody help me to figure out why the interfaces are in a waiting state? especially outside interface.
Failover On
Failover unit Secondary
Failover LAN Interface: bds-failover GigabitEthernet0/2 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 3 of 250 maximum
Version: Ours 8.2(1), Mate 8.2(1)
Last Failover at: 09:32:25 UTC Oct 20 2011
        This host: Secondary - Standby Ready
                Active time: 140 (sec)
                slot 0: ASA5520 hw/sw rev (2.0/8.2(1)) status (Up Sys)
                  Interface outside (10.10.10.11): Normal (Waiting)
                  Interface management (0.0.0.0): No Link (Waiting)
                  Interface inside (192.168.6.2): No Link (Waiting)
                slot 1: empty
        Other host: Primary - Active
                Active time: 12768 (sec)
                  Interface outside (10.10.10.10): Normal (Waiting)
                  Interface inside (192.168.6.1): No Link (Waiting)
                slot 1: empty
Stateful Failover Logical Update Statistics
        Link : bds-failover GigabitEthernet0/2 (up)
        Stateful Obj    xmit       xerr       rcv        rerr
        General         1675       0          3403       0
        sys cmd         1672       0          1672       0
        up time         0          0          0          0
        RPC services    0          0          0          0
        TCP conn        0          0          0          0
        UDP conn        0          0          0          0
        ARP tbl         3          0          1731       0
        Xlate_Timeout   0          0          0          0
        VPN IKE upd     0          0          0          0
        VPN IPSEC upd   0          0          0          0
        VPN CTCP upd    0          0          0          0
        VPN SDI upd     0          0          0          0
        VPN DHCP upd    0          0          0          0
        SIP Session     0          0          0          0
        Logical Update Queue Information
                        Cur     Max     Total
        Recv Q:         0       17      17077
        Xmit Q:         0       1       1741
Pratik
19 Replies 19
V S Narayana Chivukula
Hi Pratik,
The interfaces would be in 'waiting' state when they have not heard a 'hello' message from the other unit in failover. Please check the following link which gives you information about why the hello message is not received :
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml#Monitor
Narayana
Hi Narayana,
I am using a HP Procurve 2650 switch in between the 2 firewalls for failover. Can you help me in configuring spanning tree portfast in the HP switch?
I suspect thats the reason why interfaces are in waiting state.
Pratik
Hi Pratik,
In general the 'portfast' will place the switch port into forwading state quickly thank non portfast configured interface.
So even when the portfast is not enabled on the switch ports,  the FW should exchange hellos in max 40-50Sec when
the interfaces connected to switch. It sounds like it is more than portfast issue.  Check whether the ports on procurve configured as 'edge-ports' and also in same vlan. This should allow the hello.
Here is example for edge port (google ;-)):
spanning-tree 11-30 edge-port
hth
MS
MS,
I made the ports edge ports in the HP switch. But still no luck. I have a few questions just to be sure i did everything right.
I have used straight cable to connect a cisco 3900 router to cisco asa 5520. I assume all cisco routers and firewall ports are now auto sensing.
Below is my show failover.
Failover On     slot 1: empty
Failover unit Primaryecondary - Standby Ready
Failover LAN Interface: failover GigabitEthernet0/2 (up)
Interface Policy 100000    128      Disabled   |
Monitored Interfaces 2 of 250 maximumisabled   |
Version: Ours 8.2(1), Mate 8.2(1)   Disabled   |
Last Failover at: 07:53:22 UTC Oct 25 2011ed   |
  35   1This host: Primary - Active Disabled   |
  36   10/100TX Active time: 12790 (sec)bled   |
  37   10/100TX slot 0: ASA5520 hw/sw rev (2.0/8.2(1)) status (Up Sys)
  38   10/100TX   Interface outside (10.10.10.1): Normal (Waiting)
  39   10/100TX   Interface management (192.168.6.1): No Link (Waiting)
  40   10/100TX slot 1: empty8      Disabled   |
  41   1Other host: Secondary - Standby Ready  |
  42   10/100TX Active time: 68574 (sec)bled   |
  43   10/100TX slot 0: ASA5520 hw/sw rev (2.0/8.2(1)) status (Up Sys)
  44   10/100TX   Interface outside (10.10.10.2): Normal (Waiting)
  45   10/100TX   Interface management (192.168.6.2): No Link (Waiting)
  46   10/100TX slot 1: empty8      Disabled   |
  47   10/100TX  200000    128      Disabled   |
Stateful Failover Logical Update Statisticsd   |
  49   1Link : failover GigabitEthernet0/2 (up)
  50   1Stateful Obj 0  xmit       xerr       rcv        rerr
        General         3494       0          2054       0
        sys cmd         1750       0          1750       0
        up time         0          0          0          0
        TCP conn        0          0          0          0
        UDP conn        0          0          0          0
        ARP tbl         1745       0          305        0
        VPN IKE upd     0          0          0          0
        VPN SDI upd     0          0          0          0
        SIP Session     0          0          0          0
                        Cur     Max     Total
        Recv Q:         0       17      3609
        Xmit Q:         0       1024    17744
I dont know what else to do. I m running out of options now.
Pratik
Pratik,
What exactly mean by "I have used straight cable to connect a cisco 3900 router to cisco asa 5520"?.
Both ASAs failover i/f connected via switch or router?  Please shed some light physical infrastructure and also post the
FW config..
Thx
MS
I meant to say that I used a straight cable between the cisco 3900 router and ASA 5520.
Below is FW's running config,
hostname ciscoasa
enable password Fk/FKoeyrw2FML8Z encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0/0
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
description LAN/STATE Failover Interface
interface GigabitEthernet0/3
nameif outside
security-level 0
ip address 10.10.10.1 255.255.255.0 standby 10.10.10.1
interface Management0/0
nameif management
security-level 100
ip address 192.168.6.1 255.255.255.0 standby 192.168.6.2
management-only
ftp mode passive
pager lines 24
logging asdm informational
mtu outside 1500
mtu management 1500
failover
failover lan unit primary
failover lan interface failover GigabitEthernet0/2
failover key *****
failover link bds-failover GigabitEthernet0/2
failover interface ip bds-failover 10.10.1.1 255.255.255.0 standby 10.10.1.2
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
service resetoutside
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:3015c118ae16aff18f87064c57f8380e
: end
One cisco 3900 router is connected to each firewall.
Let me know if you require any other details.
Pratik
I doubt if the link comes up without Xover cable or not using auto MDIX / switch module on 3900. Also, please correct the config...
nameif outside
security-level 0
Standby address showing the same as interface ip.
Thx
MS
Sorry that was a typo. Standby ip is 10.10.10.2.
So you suggest to use a crossover cable between the router and firewall?
Pratik
ASA interface connected to 3900 L3 interface or any switching module. If is it Ip assigned interface, what is the status?
L3-L3 connection should be done thru a Xover cable or place switch between those devices.
Thx
MS
I changed the cable between the router and firewall to a crossover one. but it didnt make a difference. the interfaces are still in the waiting state.
Pratik
Hi Pratik,
I asked to change the cable as the basic connection (ASA<-->router) does not work with a straight cable bet L3-l3 interface. The failover issue is related to hellos between ASAs via procurve. Your config is straight forward.
Does the procurve switch links are up and both ASAs interfaces are in same vlan? if possible can you test by
moving the connections to another switch?
Thx
MS
MS,
The switch links are up and both asa interfaces are on same vlan. Actually i am using the default vlan.
I dont know if this would help here but the link light on the ASA interfaces which connect to the Cisco 3900 routers are always solid amber.
Pratik
Pratik,
You need to do general doc checkup on LED and any other connection details on ASA. There is lot of useful information Cisco website itself. The Amber basically indicates 1gig link speed.
http://www.cisco.com/en/US/docs/security/asa/hw/maintenance/guide/overview.html
As far as the failover status...
post the both ASAs models, OS version, memory & flash info
I would recommend you swap procurve with another basic switch and see if that helps.
This may sound strange, but try rebooting all the gear (ASAs and switch with proper maintenanace window).
Also, if you have a crossover cable try connecting both ASA failover interfaces directly and see if that works.
Thx
MS
MS,
I have attached 'show version' for both primary and secondary firewalls.
Also, I reloaded primary firewall, hp switch and secondary firewall in sequence. But still no luck.
I also replaced the HP switch with a L3 Gigabit switch and also with a l2 switch. But still no luck.
When I do 'no failover active' on primary, it switches to secondary without any problem and it switches back to primary when i add 'failover active' on primary. But the interfaces still remain in the waiting state.
Pratik
