AIP-SSM-20 shunning problem for block host request
Mammad Mammadov
I enable signature 2000 for testing for request block connection on ASA. But it isn't work. Device login profile and connection between ASA and AIP-SSM are correct. I see the following error in Event Viewer:
evError: eventId=1297944335862322485  vendor=Cisco  severity=error
  originator:
    hostId: sensor
    appName: nac
    appInstanceId: 419
  time: окт 02, 2012 10:32:55 UTC  offset=240  timeZone=GMT+04:00
  errorMessage: Attempted to shun Sensor [10.x.x.x]  name=errUnacceptableValue
Can you help me?
sawgupta
Could you try directly configuring on ASA, does it work then ?
http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_configuration_example09186a0080afe111.shtml#shun
What is the software version on ASA and IPS module ? Could you upgrade to latest if required.
Sawan Gupta
Thanks & Regards, Sawan Gupta
Mod Card Type                                    Model
  0 ASA 5520 Adaptive Security Appliance         ASA5520
  1 ASA 5500 Series Security Services Module-20  ASA-SSM-20
Mod MAC Address Range                 Hw Version   Fw Version   Sw Version
  0 70ca.9b6e.0116 to 70ca.9b6e.011a  2.0          1.0(11)5     8.2(5)
  1 001f.ca09.2681 to 001f.ca09.2681  1.0          1.0(11)5     7.0(4)E4
Mod SSM Application Name           Status           SSM Application Version
  1 IPS                            Up               7.0(4)E4
Mod Status             Data Plane Status     Compatibility
  0 Up Sys             Not Applicable
There is the following document on Cisco.com:
http://www.cisco.com/image/gif/paws/111001/shun-block-config-ex.pdf
"Connection blocks are not supported by security appliances. Security appliances only support host blocks with optional port and protocol information."
request-block-connection is used to block traffic on Cisco IOS (Using ACLs) so it's not applicable for ASA. On ASA Use request-block-host instead.
