Allow traceroute & Ping from ASA's Outside Interface to Inside Interface
accenture-bang2
I want to allow traceroute & Ping from ASA's Outside Interface to Inside Interface.
Pls share the details
XIE YAO
IF you want to allow ping from INSIDE to OUTSIDE,
For ping, inspect ICMP should work,
For traceroute, you have to add below acl on outside interface(inbound)
access-list ICMP extended permit icmp any any unreachable
access-list ICMP extended permit icmp any any time-exceeded
access-list ICMP extended permite icmp any any echo-reply
IF the direction is from OUTSIDE to INSIDE, then,
For ping, you have to add one more entry.
access-list ICMP extended permit icmp any any echo
For traceroute, if it is windows Tacert, then nothing else to add, but if it's Cisco ios or Linux, then it's a bit complex as they typically addressed to a pseudorandom high port, AFAIK, it's difficult to precisely define, have to use some more general acl.
XIE
For ping, make sure to have the icmp inspection enabled.
For traces, create a new class-map just for the ICMP traffic, associate it to the default policy-map and use this command:
"set connection decrement-ttl".
I.e
Access-list ICMP-list permit icmp any any
Class-map ICMP-class
match access-list ICMP-list
Policy-map global_policy
class ICMP-class
