CISCo ASA web filter using regex
AHMEDMAHMOUD
Frequent Visitor
Frequent Visitor
Dear all
i work for the folloiwng configuration to allow ssome websites for internal users , i test all the configuration and it is running ok , the point what i face is when i try to browse yahoo.com , some of the page content doesnot appear as showed down in the page . the point that i try to check what the problem but invain ,
ASA Version 8.4(2)
hostname ciscoasa
enable password qM2/Rr9J2rEGCCSH encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
description TO-ISP
nameif outside
security-level 0
ip address 172.16.1.2 255.255.255.0
interface Ethernet0/1
no nameif
no security-level
no ip address
interface Ethernet0/1.50
description Data-vlan
vlan 50
nameif inside1
security-level 100
interface Ethernet0/1.60
description Wlan-Vistor-Vlan
vlan 60
nameif inside2
security-level 50
ip address 192.168.4.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif managament
security-level 0
ip address 192.168.5.1 255.255.255.0
management-only
regex domainlist10 "\.cibworld\.nl"
regex domainlist11 "\.nbe\.com"
regex domainlist20 "\mustathmir\.net"
regex domainlist12 "\.alwatany\.net"
regex domainlist21 "\holding\.com"
regex domainlist13 "\.alahlynet\.com"
regex domainlist22 "\org\.eg"
regex domainlist14 "\.imc-egypt\.org"
regex domainlist23 "\.elwatannews\.com"
regex domainlist15 "\.ida.gov\.eg"
regex domainlist16 "\itc-egypt\.org"
regex domainlist17 "\.gov\.eg"
regex domainlist18 "\eg\.com"
regex domainlist19 "\cairofair\.com"
regex domainlist1 "\.yahoo\.com"
regex domainlist2 "\.hotmail\.com"
regex domainlist4 "\.live\.com"
regex domainlist5 "\youm7*\.com"
regex domainlist6 "\.nsgb\.com"
regex domainlist7 "\.netabank\.net"
regex domainlist8 "\.google\.com"
regex domainlist9 "\.cibeg\.com"
ftp mode passive
clock timezone EEST 2
clock summer-time EEDT recurring last Fri Apr 0:00 last Fri Sep 0:00
dns domain-lookup outside
dns server-group DefaultDNS
name-server 172.16.1.1
same-security-traffic permit intra-interface
object network DataVLAN
subnet 192.168.1.0 255.255.255.0
description Data VLAN
object network Wirelessvlan
subnet 192.168.4.0 255.255.255.0
description Wireless vlan
object network test
host 192.168.1.22
description test
object network 192.168.1.8
host 192.168.1.8
object-group network Some_Internet
network-object host 192.168.1.13
network-object host 192.168.1.106
network-object host 192.168.1.6
network-object host 192.168.1.20
network-object host 192.168.1.18
network-object host 192.168.1.14
network-object host 192.168.1.12
network-object host 192.168.1.17
network-object host 192.168.1.11
network-object host 192.168.1.5
network-object host 192.168.1.7
network-object host 192.168.1.15
network-object host 192.168.1.16
network-object object 192.168.1.8
object-group-search access-control
access-list inside1_access_in extended permit tcp any any eq telnet
access-list inside1_access_in extended permit ip any any
access-list AllowedSites extended permit tcp object-group Some_Internet any eq www
access-list AllowedSites extended permit tcp object-group Some_Internet any eq 8080 inactive
access-list AllowedSites extended deny tcp object DataVLAN any eq www
access-list AllowedSites extended deny tcp object DataVLAN any eq 8080 inactive
access-list outside_access_in extended permit icmp 172.16.1.0 255.255.255.0 any
access-list inside2_access_in extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside1 1500
mtu inside2 1500
mtu managament 1500
ip verify reverse-path interface outside
ip verify reverse-path interface managament
ip audit info action alarm drop
ip audit attack action alarm drop
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
no asdm history enable
arp timeout 14400
nat (inside1,outside) dynamic interface dns
nat (inside2,outside) dynamic interface dns
nat (inside1,outside) after-auto source dynamic any interface
access-group outside_access_in in interface outside
access-group inside1_access_in in interface inside1
access-group inside2_access_in in interface inside2
route outside 0.0.0.0 0.0.0.0 172.16.1.1 1
timeout xlate 1:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
no user-identity enable
user-identity default-domain LOCAL
http server enable
http 192.168.5.0 255.255.255.0 managament
http 192.168.1.0 255.255.255.0 inside1
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet 192.168.1.0 255.255.255.0 inside1
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map type regex match-any Domain-Allowed-List
match regex domainlist10
match regex domainlist22
match regex domainlist21
match regex domainlist12
match regex domainlist11
match regex domainlist20
match regex domainlist14
match regex domainlist13
match regex domainlist16
match regex domainlist15
match regex domainlist18
match regex domainlist17
match regex domainlist19
match regex domainlist5
match regex domainlist4
match regex domainlist7
match regex domainlist6
match regex domainlist9
match regex domainlist8
match regex domainlist23
class-map inspection_default
match default-inspection-traffic
class-map type inspect http match-all asdm_high_security_methods
match not request method head
match not request method get
class-map httptraffic
match access-list AllowedSites
class-map type inspect http match-all Domain-Allowed-Class
match not request header host regex class Domain-Allowed-List
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map type inspect http http_inspection_policy
parameters
class Domain-Allowed-Class
drop-connection log
match request method connect
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect ipsec-pass-thru
class class-default
user-statistics accounting
policy-map inside-policy
class httptraffic
service-policy global_policy global
service-policy inside-policy interface inside1
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:0c9f3c5d28823228b53613f19e4a282b
: end
jocamare
Level 9
Level 9
Assuming you have tried the same website from different browsers and boxes, i would suggest removing the regex configuration temporarily [preferably after working hours] and try it again.
no service-policy inside-policy interface inside1 --> disables
service-policy inside-policy interface inside1 ---> enables
