Allowing redirected Traffic in and out the same interface
Patrick.Beaven
In the past using the Cisco pix. If i had a network that existed through another router or switch and the gateway was the pix you could configure a "route inside" command and the traffic coming in the trusted interface would be redirected to the appropriate gateway. I can't seem to do this with the Cisco ASA. Does anyone know of a method of redirecting traffic on an ASA back out the same port it came from? Any help is appreciated!
ajagadee
The feature that you are looking for is called "Intra-Interface Communications". Below is the URL with details:
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080734db7.shtml#topic2
Arul
** Please rate all helpful posts **
1cmerchant
The command 'same-security-traffic permit intra-interface' should allow this.
Carl
