Analysis engine fails frequently.
egain.com
Level 3
Level 3
hi, Recently i deployed ips4240 inline -with software versions -
IPS-K9-sp-5.0-6
IPS-sig-S242-minreq-5.0-6.pkg
I found that the Analysis engine keeps failing (please refer the screen msg below).
I am using one pair of interface for in-line configuration and I have modified quite a few signature response to drop the packets.
egsensor# SH STATISTICS ANALysis-engine
Error: getAnalysisEngineStatistics : ct-sensorApp.338 not responding, please che
ck system processes - The connect to the specified Io::ClientPipe failed.
b.hsu
Level 11
Level 11
uninstall and try by reinstalling the signatue file
Try restarting the analysis engine...
1. Log into service account
2. su to root
3. Type /etc/init.d/cids restart
4. su to cisco
5. Type sho stat analysis-engine
6. Send me the printout
I have the same problem.
sensor# sh statistics analysis-engine
Error:getAnalysisEngineStatistics: ct-sensorApp.421 not responding,please check system processes - The connect to the specified Io::ClientPipe failed
