Analysis engine fails frequently.
egain.com
hi, Recently i deployed ips4240 inline -with software versions -
IPS-K9-sp-5.0-6
IPS-sig-S242-minreq-5.0-6.pkg
I found that the Analysis engine keeps failing (please refer the screen msg below).
I am using one pair of interface for in-line configuration and I have modified quite a few signature response to drop the packets.
egsensor# SH STATISTICS ANALysis-engine
Error: getAnalysisEngineStatistics : ct-sensorApp.338 not responding, please che
ck system processes - The connect to the specified Io::ClientPipe failed.
b.hsu
Level 5
Level 5
uninstall and try by reinstalling the signatue file
Try restarting the analysis engine...
1. Log into service account
2. su to root
3. Type /etc/init.d/cids restart
4. su to cisco
5. Type sho stat analysis-engine
6. Send me the printout
I have the same problem.
sensor# sh statistics analysis-engine
Error:getAnalysisEngineStatistics: ct-sensorApp.421 not responding,please check system processes - The connect to the specified Io::ClientPipe failed
