Analysis Engine not starting after 6.1 upgrade
mcvosi
The Analysis Engine on my sensor is not starting after the upgrade to 6.1.
Also, when I use IDM to connect to the sensor it says:
Error connecting to sensor. Failed to create sensor - <IP address>.
Exiting IDM.
smahbub
Level 6
Level 6
Can you provide the output of commands "show tech" and "show version" which will help us in identifying the reason for the issue and resolving the same.
avang2004
You might be running into this bug #CSCsm71528
Symptom:
After signature update or configuration change the AnalysisEngine shows NotRunning.
Conditions:
After a signature update or other configuration change.
Workaround:
None, to restore service reboot sensor.
