ASA 5505 Does not like using comma's (Setting up Port Forwarding)
ASA Version 8.2(5)
Device Manger Version 6.4(5)
So I'm trying to setup port forwarding for a single camera with an ip address and its using port 80 to stream the video feed. I think I have most of it setup however when I get to the nat command it keeps hanging on an error with the comma (,). These are my commands so far to get to where I am.
ASA>
ASA> en
Password: ********
ASA#
ASA# config t
ASA(config)#
ASA(config)# object network ASA-Camera
ASA(config-network)# network-object host 10.10.2.150
ASA(config-network)# nat (inside,outside) static interface service tcp http http
~Here is the error I get~
ERROR: % Invalid input detected at '^' marker.
ASA(config-network) #
I'm using putty as the program.
@SugarloafWaterAssociation I note you are using ASA 8.2 which uses different NAT syntax, here is an example using the old syntax. https://travelingpacket.com/2014/08/04/cisco-asa-8-2-and-below-static-nat/
7 Replies 7
Sorry I thought this uploaded but it did not.
@SugarloafWaterAssociation try this
 host 10.10.2.150
This gives me an error on the host command
ASA# config t
ASA(config)#
ASA(config-network)# host 10.10.2.150
ERROR: Invalid hostname: '10.10.2.150'
INFO: A hostname must start and end with a letter or digit, and have as interior characters only letters, digits, or a hyphen.
This code was at least accepted. If the internal ip address changed how would I make that change in ASA?
Still trying to gain access through the modem and firewall so I can't quiet accept this as an answer just yet.
ASA(config)# object network ASA-Cam <<- change the name may be OLD object network effect new one.
Would this be possible if I just created this network object last week? By that I mean in the last 6 years of owning this device I have been the only to program it and I know I have never used that as a network object.
